NI Ettus USRP X410
787272-01
QTY:
USRP X410
$29,950.00 USD
787272-01
QTY:
IMPORTANT: Please select the power cord that is compatible with your region from the list below.
QTY:
The regional power cord is a REQUIRED accessory, and is NOT INCLUDED in the kit of this product.
USRP X410 (4 TX/RX Channels, 400 MHz BW, Zynq US+ RFSoC ZU28DR)
The NI Ettus USRP X410 is a high-performance, multi-channel, Zynq US+ RFSoC based software defined radio (SDR) for designing and deploying next generation wireless systems.
The NI Ettus USRP X410 is a high-performance, multi-channel software-defined radio. The SDR  is designed for frequencies from 1 MHz to 7.2 GHz, tunable up to 8 GHz and features a two-stage superheterodyne architecture with 4 independent TX and RX channels capable of 400 MHz of instantaneous bandwidth each.  Digital interfaces for data offload and control include two QSFP28 interfaces capable of 100 GbE, a PCIe Gen3 x8 [1] interface, as well standard command, control, and debug interfaces: USB-C JTAG, USB-C console, Ethernet 10/100/1000. The USRP X410 is an all-in-one device built on the Xilinx Zynq Ultrascale+ ZU28DR RF System on Chip (RFSoC) with built-in digital up and down conversion and onboard Soft-Decision Forward Error Correction (SD-FEC) IP.
Use the software of your choice
The NI Ettus USRP X410 is fully supported on the popular open-source USRP Hardware Driver (UHD) version 4.1 or later[2].  UHD 4.1 was designed to support the large data movement requirements imposed by the 400 MHz bandwidth and multiple channels onboard. The USRP X410 supports open-source SDR design flows such as C/C++ and GNU Radio, as well as LabVIEW FPGA [1]. Unlike other RFSoC-based systems, the USRP X410 is fully ready to port your previous UHD designs to take advantage of high-performance capabilities with a simple recompile.
Networked / Stand-Alone Operation
Since the USRP X410 is built on the ZU28DR RF System on Chip (RFSoC) device, it comes equipped with a quad-core ARM Cortex-A53 processing subsystem, clocked up to 1.2 GHz for stand-alone application requirements. Additionally, the RFSoC contains a dual-core ARM Cortex-R5 real-time processing unit for onboard monitoring and control.
Built-In IP
The onboard RFSoC on the USRP X410 contains more than twice the FPGA programmable logic resources than that of the previous generation X-series USRP devices. In addition, the ZU28DR comes with 8 soft-decision forward error correction (SD-FEC) hard IP cores, ideal for wireless communication systems. Given the high-speed nature of the built-in ADCs and DACs to the RFSoC, the Zynq device has 8 digital upconversion and digital down-conversion IP cores allowing for rapid in-band retuning or signal reduction.
Multi-Radio Synchronization
Multi-radio clocking and timing synchronized operation is possible with the built-in GPSDO (GPS disciplined oscillator) or with the 10 MHz reference and 1 PPS (Pulse Per Second) input signal interfaces. Multi-Radio phase-aligned and phase-coherent operations are not supported, as RF chain LO import and export functionality is not supported on the USRP X410.
[1] PCIe Gen3 x8 is only supported by NI-USRP and LabVIEW FPGA design flows
[2] 100 GBE supported in UHD 4.2 or later
Features
Features
  • High channel density
    • 12 bit ADC, 14 bit DAC
    • Onboard SD-FEC, DDC, DUC
  • RJ45 (1 GbE) [1]
  • 10 MHz Clock reference
  • PPS time reference
  • Trig In/Out Interface
  • Built-in GPSDO
  • 1 Type C USB host port
  • Watchdog timer
  • OpenEmbedded Linux
  • USRP Hardware Driver™ (UHD) open-source software API version 4.1.0 or later
  • RF Network on Chip (RFNoC™) FPGA development framework
  • Xilinx Vivado® 2019.1 Design Suite (license not included)
  • GNU Radio support is maintained by Ettus Research™ through GR-UHD, an interface to UHD distributed by GNU Radio
[1] The RJ45 port is used for remote management of the device and does not support IQ streaming.
Additional Resources
Built-In IP
Features
  • RJ45 (1 GbE) [1]
  • Built-in GPSDO
  • Watchdog timer
Compatible Products
This power cord allows the...
$25.00 USD
QTY:
$25.00 USD
QTY:
This power cord allows the 12...
$25.00 USD
QTY:
$25.00 USD
QTY:
$24.00 USD
QTY:
$25.00 USD
QTY:
$25.00 USD
QTY:
Compatible Products
$25.00 USD
QTY:
$25.00 USD
QTY:
$25.00 USD
QTY:
$25.00 USD
QTY:
$24.00 USD
QTY:
$25.00 USD
QTY:
$25.00 USD
QTY:
