Board Mounted GPSDO (OCXO) Recommended for USRP X300/X310
$2,033.00 USDGPSDO for USRP X Series (PCB-Mounted GPS-Disciplined OCXO)
This is a GPS-disciplined, oven-controlled crystal oscillator (GPSDO), which is compatible with a USRP X300 or X310. The GPSDO provides a high-accuracy 10 MHz reference and 1 PPS signal. This allows developers to build system that serve applications with tight synchronization requirements, or global timing alignment within 50 ns.
This is a GPS-disciplined, oven-controlled crystal oscillator (GPSDO), which is compatible with a USRP X300 or X310. It can also be used with the USRP B200/B210, but the system will require external power. The GPSDO provides a high-accuracy 10 MHz reference and 1 PPS signal, which allow developers to build systems that serve applications with improved frequency accuracy and global timing alignment.
We recommend reading the GPSDO Selection Guide to ensure this is the right device for your application.
Module Specifications
1 PPS Accuracy
±50ns to UTC RMS (1-Sigma) GPS Locked
Holdover Stability
<±20µs over 3 hour period at +25C
1 PPS Output (OCXO Flywheel Generated)
3.3VDC CMOS
RS-232 Control
NMEA & SCPI-99 Control Commands, Integrated into UHD
GPS Frequency
L1, C/A 1574MHz
GPS Antenna
Active (5V compatible) or Passive
GPS Receiver
50 Channels, Mobile, WAAS, EGNOS, MSAS capable
Sensitivity
Acquisition -142dBm, Tracking -168dBm
TTFF
Cold Start: <45 sec, Warm Start: 1 sec, Hot Start: 1 sec
ADEV
1E-11 at 1s
Warm Up Time / Stabilization Time
<5 min at +25C to 1E-08 Accuracy
Supply Voltage (Vdd)
3.3/5VDC
Power Consumption
0.7W Max
Operating Temperature
0C to +60C
Storage Temperature
-45C to 85C
Oscillator Specifications
Frequency Output
10MHz
10MHz Retrace
±2E-08 after 1 hour at 25C
Frequency Stability Over Temperature (Unlock Condition)
±2.5E-08
Warm Up Time
< 1 min at +25C
Phase Noise at 10MHz
1Hz
-75dBc/Hz
10Hz
-110dBc/Hz
100Hz
-132dBc/Hz
1kHz
-142dBc/Hz
10kHz
<-145dBc/Hz
Additional Resources
Kit Contents:
- Board-Mounted GPSDO (OCXO)
- Documentation for Installation and Configuration/Setup
Recommended for Use With:
- A USRP X300 and USRP X310 for a high-accuracy clock reference.
- Add a GPSDO Mini GPS Antenna to synchronized the GPSDO to the GPS constellation for 25 ppb frequency accuracy and 50 ns alignment across the globe.
Additional Information:
Module Specifications |
1 PPS Accuracy |
±50ns to UTC RMS (1-Sigma) GPS Locked |
Holdover Stability |
<±20µs over 3 hour period at +25C |
1 PPS Output (OCXO Flywheel Generated) |
3.3VDC CMOS |
RS-232 Control |
NMEA & SCPI-99 Control Commands, Integrated into UHD |
GPS Frequency |
L1, C/A 1574MHz |
GPS Antenna |
Active (5V compatible) or Passive |
GPS Receiver |
50 Channels, Mobile, WAAS, EGNOS, MSAS capable |
Sensitivity |
Acquisition -142dBm, Tracking -168dBm |
TTFF |
Cold Start: <45 sec, Warm Start: 1 sec, Hot Start: 1 sec |
ADEV |
1E-11 at 1s |
Warm Up Time / Stabilization Time |
<5 min at +25C to 1E-08 Accuracy |
Supply Voltage (Vdd) |
3.3/5VDC |
Power Consumption |
0.7W Max |
Operating Temperature |
0C to +60C |
Storage Temperature |
-45C to 85C |
Oscillator Specifications |
Frequency Output |
10MHz |
10MHz Retrace |
±2E-08 after 1 hour at 25C |
Frequency Stability Over Temperature (Unlock Condition) |
±2.5E-08 |
Warm Up Time |
< 1 min at +25C |
Phase Noise at 10MHz |
1Hz |
-75dBc/Hz |
10Hz |
-110dBc/Hz |
100Hz |
-132dBc/Hz |
1kHz |
-142dBc/Hz |
10kHz |
<-145dBc/Hz |
Kit Contents:
Compatible Products
Compatible Products
