783480-01
QTY:
5-Volt Active GPS Antenna for USRP X300/X310 and B200/B210
$113.00 USD
783480-01
QTY:
GPS ANTENNA, MAGNETIC MOUNT, 5M CABLE WITH SMA
This is a 5V active GPS antenna intended for use with the Board-Mounted GPSDO (OCXO) or Board-Mounted GPSDO (TCXO).  A GPSDO locked to the GPS constellation can provide time synchronization within 50 ns of the global GPS standard and very high clock accuracy.
Note:  This antenna is NOT compatible with the GPSDO used with  USRP N200/N210.
Additional Resources
Note:  This antenna is NOT compatible with the GPSDO used with  USRP N200/N210.Kit Contents:
  • 5V Active GPS Antenna
Recommended for Use With:
Additional Information:
