3-Volt Active GPS Antenna for N Series
$113.00 USDGPS ANTENNA, MAGNETIC MOUNT, 5M CABLE WITH SMA
This is a 3V active GPS antenna intended for use with the GPSDO kit used with the USRP N200/N210 Series. The antenna can also be used for the USRP E310, which has an integrated GPS(SMA to SMB adapter needed). A GPSDO locked to the GPS constellation can provide time synchronization within 50 ns of the global GPS standard and very high clock accuracy.
Note: This antenna is NOT compatible with the GPSDOs used with USRP X300/X310 and B200/B210.
Kit Contents:
- 3V Active GPS Antenna
Recommended for Use With:
Kit Contents:
