USRP B200mini (Board only)
$1,306.00 USDUSRP B200MINI Board only (1X1, 70 MHZ - 6 GHZ) - ETTUS RESEARCH
The USRP™ B200mini delivers a 1×1 SDR/cognitive radio in the size of a business card.
The USRP™ B200mini delivers a 1×1 SDR/cognitive radio in the size of a business card. With a wide frequency range from 70 MHz to 6 GHz and a user-programmable Xilinx Spartan-6 XC6SLX75 FPGA, this flexible and compact platform is ideal for both hobbyist and OEM applications. The RF front end uses the Analog Devices AD9364 RFIC transceiver with 56 MHz of instantaneous bandwidth. The board is bus-powered by a high-speed USB 3.0 connection for streaming data to the host computer. The USRP B200mini also includes connectors for GPIO, JTAG, and synchronization with a 10 MHz clock reference or PPS time reference input signal. The USRP Hardware Driver™ (UHD) software API supports all USRP products and enables users to efficiently develop applications then seamlessly transition designs between platforms as requirements expand.
Features
Features
Wide frequency range: 70 MHz – 6 GHz
Up to 56 MHz of instantaneous bandwidth
Full duplex operation
User-programmable Xilinx Spartan-6 XC6SLX75 FPGA
Fast and convenient bus-powered USB 3.0 connectivity
Synchronization with 10 MHz clock reference or PPS time reference
GPIO and JTAG for control and debug capabilities
83.3 x 50.8 x 8.4 mm form factor
USRP Hardware Driver™ (UHD) open-source software API version 3.9.0 or later
GNU Radio support maintained by Ettus Research™ through GR-UHD, an interface to UHD distributed by GNU Radio
Additional Resources
- USRP B200mini Series Getting Started Guide
- USRP B200mini Series Dimensional Drawing
- USRP B200/B210/B200mini User Manual
- USRP Hardware Driver (UHD) API Documentation
- UHD Stable Binaries
- UHD Source Code on Github
- FPGA Resources
- AD9364 Product Page
- Xilinx Spartan-6 Product Page
- USRP Support from MathWorks Communications Toolbox
Included in This Kit:
- USRP B200mini board
- USB 3.0 cable
- Getting Started Guide
Related Products and Recommended Accessories:
Features
- FPGA Resources
- USB 3.0 cable
Compatible Products
Compatible Products
