USRP N200 USRP N200
782746-01
QTY:
USRP N200
$1,775.00 USD
782746-01
QTY:
USRP N200 Kit (USRP N200, 2 SMA-Bulkhead RF Cables, Ethernet Cable, Power)
The USRP N200 offers high-bandwidth, high-dynamic range processing capability. The Gigabit Ethernet interface of the USRP N200 allows high-speed streaming capability up to 50 MS/s in both directions (8-bit samples). These features, combined with plug-and-play MIMO capability make the USRP N200 an ideal candidate for software defined radio systems with demanding performance requirements.
The USRP N200 series provides high-bandwidth, high-dynamic range processing capability. The product architecture includes a Xilinx® Spartan® 3A-DSP 1800 FPGA, 100 MS/s dual ADC, 400 MS/s dual DAC and Gigabit Ethernet connectivity to stream data to host processors. A modular design allows the USRP N200 to operate from DC to 6 GHz. An expansion port allows multiple USRP N200 series devices to be synchronized and used in a MIMO configuration. An optional GPSDO module can also be used to discipline the USRP N200 reference clock to within 0.01 ppm of the worldwide GPS standard. The USRP N200 can stream up to 50 MS/s to and from host applications, and users can implement custom functions in the FPGA fabric, or in the on-board 32-bit RISC softcore. The FPGA offers the potential to process up to 100 MHz of RF bandwidth in both the transmit and receive directions. The FPGA firmware can be reloaded through the Gigabit Ethernet interface.
Additional Resources
Included in This Kit:
  • USRP N200
  • 1 Gigabit Ethernet Cable
  • Power Supply
  • 2 SMA-Bulkhead Cables
Additional Resources:
Recommended Daughterboards and Accessories:
  • USRP N200
  • Power Supply
Compatible Products
The USRP N210 is an...
$2,011.00 USD
QTY:
The BasicTX daughterboard provides a...
$88.00 USD
QTY:
The BasicRX provides a simple,...
$88.00 USD
QTY:
The LFTX utilizes high-speed operational...
$88.00 USD
QTY:
The LFRX utilizes high-speed operational...
$88.00 USD
QTY:
The TVRX2 daughterboard includes two...
The DBSRX2 is a configurable...
$178.00 USD
QTY:
The WBX is a wide...
$562.00 USD
QTY:
The SBX is a wide...
$562.00 USD
QTY:
The RFX900 is a high-performance...
Includes one LP0410 400 MHz...
$53.00 USD
QTY:
Includes one LP09650 850 MHz...
$53.00 USD
QTY:
Includes one VERT400 144 MHz,...
$75.00 USD
QTY:
Includes one VERT900 824 to...
$42.00 USD
QTY:
Includes one VERT2450 Dual Band...
$42.00 USD
QTY:
Includes one SMA-M to BNC-M...
Includes one SMA-M to SMA-M...
$35.00 USD
QTY:
Kit for USRP systems includes...
$118.00 USD
QTY:
Includes one SMA-M to SMA-F...
$23.00 USD
QTY:
Includes one MCX-M to SMA-F...
$23.00 USD
QTY:
The MIMO expansion cable is...
$83.00 USD
QTY:
Includes one Ethernet cable, CAT-5e,...
$11.00 USD
QTY:
Includes the power supply for...
$29.00 USD
QTY:
Includes a 19″ 3U Rackmount...
$296.00 USD
QTY:
Includes GPS locked reference oscillator...
$889.00 USD
QTY:
The OctoClock CDA-2990 is an...
$1,140.00 USD
QTY:
The OctoClock-G CDA-2990 is an...
$1,994.00 USD
QTY:
The CBX is a full-duplex,...
$562.00 USD
QTY:
This is a 3V active...
$60.00 USD
QTY:
The UBX 40 daughterboard is...
$1,037.00 USD
QTY:
Compatible Products
$2,011.00 USD
QTY:
$88.00 USD
QTY:
$88.00 USD
QTY:
$88.00 USD
QTY:
$88.00 USD
QTY:
$178.00 USD
QTY:
$562.00 USD
QTY:
$562.00 USD
QTY:
$53.00 USD
QTY:
$53.00 USD
QTY:
$75.00 USD
QTY:
$42.00 USD
QTY:
$42.00 USD
QTY:
$35.00 USD
QTY:
$118.00 USD
QTY:
$23.00 USD
QTY:
$23.00 USD
QTY:
$83.00 USD
QTY:
$11.00 USD
QTY:
$29.00 USD
QTY:
$296.00 USD
QTY:
$889.00 USD
QTY:
$1,140.00 USD
QTY:
$1,994.00 USD
QTY:
$562.00 USD
QTY:
$60.00 USD
QTY:
$1,037.00 USD
QTY:
