783773-01
QTY:
USRP E310
$5,432.00 USD
783773-01
QTY:
USRP E310 KIT (2x2 MIMO, 70 MHz - 6 GHz) - Ettus Research
The USRP E310 offers a portable stand-alone SDR platform designed for field deployment.
The USRP E310 offers a portable stand-alone software defined radio platform designed for field deployment. The flexible 2×2 MIMO AD9361 transceiver from Analog Devices provides up to 56 MHz of instantaneous bandwidth and spans frequencies from 70 MHz – 6 GHz to cover multiple bands of interest. RF filter banks in both the transmitter and receiver front-end enhance selectivity.
The baseband processor uses the Xilinx Zynq 7020 SoC to deliver FPGA accelerated computations combined with stand-alone operation enabled by a dual-core ARM CPU. The USRP E310 includes a rich set of peripherals such as an integrated GPS receiver for position awareness and time synchronization, as well as two host USB ports for extending storage, I/O, and communication options with off-the-shelf devices. Users can rapidly prototype and deploy designs for mobile and embedded applications with tight size, weight, and power requirements.
The USRP Embedded Series platform uses the OpenEmbedded framework to create custom Linux distributions tailored to application specific needs. The default operating system is pre-installed with the UHD software API and a variety of third party development tools such as GNU Radio. Support for the RFNoC FPGA development framework enables deterministic computations for real-time and wideband signal processing.
OEM configurations are available with reduced size and weight. These configurations may be subject to minimum order quantities. We stock a recommended partial-enclosure configuration. Please contact our sales team for further information: [email protected]
Operating System
OpenEmbedded Linux (Pre-Imaged)
Development Frameworks
UHD (Pre-Installed)
GNU Radio (Pre-Installed)
Xilinx Vivado 2015.2 Design Suite
Table 1: Operating system and development frameworks
Features
Features
  • Wide frequency range: 70 MHz – 6 GHz
  • 2×2 MIMO transceiver
  • RX, TX filter banks
  • Xilinx Zynq 7020 SoC: 7 Series FPGA with ARM Cortex A9 866 MHz dual-core processor
  • Up to 10 MS/s sample data transfer rate to ARM processor
  • Synchronization with PPS time reference
  • Integrated GPS receiver
  • 9-axis inertial measurement unit
  • Rich set of peripherals such as host USB and 1 Gigabit Ethernet
  • 133 x 68.2 x 26.4 mm form factor
  • OpenEmbedded build framework
  • USRP Hardware Driver™ (UHD) open-source software API version 3.8.0 or later
  • GNU Radio support maintained by Ettus Research™ through GR-UHD, an interface to UHD distributed by GNU Radio
  • The audio jack feature has been discontinued on the E310
Block Diagram
Block Diagram
This block diagram shows the system architecture of the USRP E310 device E310 System Block Diagram Click on image to enlarge
Additional Resources
Included in This Kit:
  • USRP E310
  • Power supply
  • 2x SMB-to-SMA adapter
  • 1 Gigabit Ethernet cable
  • USB2-to-microUSB cable
  • Imaged microSD card
  • Getting started guide
Related Products and Recommended Accessories
Operating System
UHD (Pre-Installed)
Features
Block Diagram
  • USRP E310
  • Power supply
Compatible Products
SMB Female to SMA Female...
$54.00 USD
QTY:
$54.00 USD
QTY:
Includes one pre-programmed 8GB microSD...
$64.00 USD
QTY:
This is a 3V active...
$109.00 USD
QTY:
Includes the locking power supply...
$74.00 USD
QTY:
This cable kit is intended...
$91.00 USD
QTY:
$111.00 USD
QTY:
Compatible Products
$54.00 USD
QTY:
$54.00 USD
QTY:
$64.00 USD
QTY:
$109.00 USD
QTY:
$74.00 USD
QTY:
$91.00 USD
QTY:
$111.00 USD
QTY:
